weird starting issue
Old Sep 2, 2008 | 08:16 PM
h2omelon's Avatar
h2omelon
Default weird starting issue
When I start my car it will not start until I let go of the key. It will turn over forever but will not start until I turn it back to the run position. Anyone else ever had this problem? Any ideas on how to fix this problem? I have replaced the ignition switch to no avail.
Old Sep 2, 2008 | 08:39 PM
mstngsule68's Avatar
mstngsule68
after i got the carb swap done i didnt notice that i had the coil wire on an hot when key is in run only, so it prob is something kinda like that.(where it doesnt have power on the coil when its in a start pos. check the coil wires. have a test light or a meter on the neg. wire and have someone crank it and see if it doesnt have power.
Old Sep 3, 2008 | 04:21 PM
h2omelon's Avatar
h2omelon
Unhappy
I checked the voltage at the coil today when starting.It has power in the run and start position.
Old Sep 3, 2008 | 04:28 PM
93 LX FiveO's Avatar
93 LX FiveO
my 93 did this
replaced the whole key cylinder and switch thingy
i kinda liked it like that tho.. anti-theft device
Old Sep 3, 2008 | 05:54 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
are all the wires in the correct position on the fender mount selonoid???
Old Sep 3, 2008 | 07:17 PM
h2omelon's Avatar
h2omelon
As far as I know they are all in the factory positions. They look to be the same as my 91 vert. Could it be my MSD coil?I think it is the reason my stock tach does'nt work.
Old Sep 5, 2008 | 01:50 AM
mstngsule68
could be, put the old one in there.
djbigskrilla
Sep 20, 2022 01:04 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
drfister
May 3, 2018 10:38 PM
MXBT187
Aug 20, 2015 02:36 AM
antipeterleague
Aug 18, 2015 01:50 PM
