Ignition problems
I replaced my spark plug wires from 8mm Bosch to the ford racing 9mm. After all was hooked up I went to start it and it wouldnt turn over. Thought the wires we bad so I put the stock back on. Turned it on, same thing wouldn't turn over. My battery read the same charge it always does when I turn it on. So what else could it be? Plugs? Ignition Coil? Please help!
coil?
Since it didn't do it before you started the wire change i would think you forgot something or bumped something loose. Id go back and double check all my actions.
or maybe your cap is loose.
or you put the wires on in the wrong firing order
rob
rob
Try this and verify.
If it fails, check the nipple on the coilpack to the coilpack ignition wire, if its loose replace the coilpack, same for the dizzy cap.
Make sure you get the "snap feel" for all wires.
jessicarabbit
Sep 25, 2015 12:41 PM
TfcCDR
Sep 14, 2015 12:08 PM
