Tranny fluid and Gear lube?
Old Sep 19, 2008 | 12:35 PM
1993 5.0's Avatar
1993 5.0
Default Tranny fluid and Gear lube?
What brand of tranny fluid do you guys use?
and what rear end fluid do you guys use, (brand and weight) and do we have to add friction modifier?
Thanks
Old Sep 19, 2008 | 12:44 PM
U S Marine's Avatar
U S Marine
I use Castrol synthetic trans oil. Rear end Valvoline 80/90, although, I'm going to change to Royal Purple when I do my gears. As far as friction modifier, it depends on type of carrier you have. Clutch type, yes. Cone type, No.
Old Sep 19, 2008 | 02:31 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
I use Royal Purple in my trans and diff. Most synthetics already have the friction modifier in it. The Royal Purple does. 75/90 in the diff and the trans uses automatic fluid.
Old Sep 19, 2008 | 03:31 PM
1993 5.0's Avatar
1993 5.0
Thanks for the reponses.
So the manual trans uses AT fluid right?
Old Sep 19, 2008 | 03:39 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Yup
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
2poor4u2
Sep 26, 2015 11:08 AM
Sep 25, 2015 06:42 PM
