Smog Pump Removal ? (All Precautions)
I know it has been on here before but i bought everything new for my car (tranny, crate engine, exausht, intake, intake manifold, etc.) so it is all ready now to be put all back together. But i want to know what i have to do with the holes in the heads from the smog pump. I know your not sepost to put the bolts back in there because it will give you a nasty leak so i want to know what are all the steps to getting it done. Plus what is the best belt size for the new configuration. Then also what is the best map for it to go around through the pullies. Just tell me all the steps that i should do and any precautions on the way. THANKS!!!!!!!!!
RE: Smog Pump Removal ? (All Precautions)
hmmmm sounds good anymore suggestions? and what lines should i plug up other then the pipeing to the heads. Also vaccuum lines that i should worry about. THANKS!!!!
there are two vacuum lines that run to the hoses that come out of the smog pump, plug them both. you wil also want to get rid of the egr crap. i think ebay sells this thing you can plug into the electrical sensor to keep the check engine light from coming on. there is also a vacuum line going to the egr valve that needs to be plugged
i used 9/16 coarse thread bolts to plug the holes. (9/16 is the bolt size not the size of the head) they were an inch long so i used washers as spacers because they wouldnt thread all the way in. or you could cut them. no leaks here.
steve
steve
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
