390 in a fox body anyone?
Old Oct 12, 2008 | 08:45 PM
Snk_Bit_Cpe's Avatar
Snk_Bit_Cpe
Originally Posted by jtmustang
390's and 460's are not the same block , i know i have built a few of them and had many more, they are not both fe motors they are quite different different stroke,rods,pistons, and the only ford motor where the pushrods go through the intake and not the head. very different and both motors are very heavy.
The 460 is in a engine family know as the 385 and 360/390 are FE motors, the last time a FE was used was in the 77 F-series in a couple of different sizes mostly medium duty trucks. The only trannys I know that will go behind them are a C-6 or Ford's 10 bolt toploader, the trans that is in your landlord's truck is probably a NP-235 with the granny low first gear. Putting a FE in a fox would be quite a project and probably really not worth the gain for the work. But if you do keep us posted cause it will be interesting to watch this build!
Old Oct 12, 2008 | 09:46 PM
jtmustang's Avatar
jtmustang
Originally Posted by 86GT 93LX
so are you saying the push rods go thru the intake on a 390?
as far as i know the 360 and 390 are the same block right? just different stroke
yep pushrods go through the intake very rare i think chrysler has 1 motor also thats the same thing
and yes 352-428 are ll the same blocks just different length strokes,cams,heads and such
and the 4 speed that is behind the 390 in the 74 is most likely a np435 with granny low and useles in a car as 1 is really low
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
RCS02v6
Sep 29, 2015 01:46 PM
GLOCKer
Sep 28, 2015 07:36 AM
2poor4u2
Sep 26, 2015 11:08 AM
