Head gasket question
Someone please explain the correct way to place the head gasket on the block............... bc i have a leaks on each head on the back corners. From what i remember the had front labeled on them which i placed towards the front. i'm not too pissed that i have to pull everything back off becuase this was my first time to do anything like this so i see it all as a learning experience. i remember there was a thick blue outling the water jackets and i i didn't know which way that faced.
So questions.
Can i re use the head gaskets if they look ok?
Can i re use intake gaskets?
also the oil/coolant looks like it mixed. WHen i moved the flywheel plate thing i saw the second leak drip down, it looked green but gooy. thanks
So questions.
damnit.
then i have no clue what happened. i even called the trickflow to confirm the torque specs and sequence.
there not labeled left and right are they? i can't remember
Luke9222
10-22-2015 11:55 PM
