23 tooth should work fine ...aren't you going to hurt you mpg??
You know me too well. That was a big concern, but fortunately I will be starting work in nyc this summer and I have been taking the train to commute so I drive the car maybe 400 miles a month if that. I can afford to play, especially if gas wants to stay as low as it is.
its cake. unbolt the 1 bolt holding the cable in, pull cable out of trans, remove clip, slide gear off, slide gear on, replace clip, insert cable, replace bolt.
