1st gear sticking
1st gear sticking
I have a 1979 Mercury Capri and just within the last 2 weeks its been really hard to get it into first gear. It's only hard when the car is moving. All the other gears work fine, it's only in first gear. If the car is stationary its perfectly fine. Any ideas?
because all pushing the clutch in does is stop the input shaft from spinning...not the output shaft, where gears 1-3 are located the way the tranny was designed was to shift from 2nd to first while either at rest or just before coming to a stop, also you could have wear on blocker rings and synchronizers contributing to some degree of difficult shifting, make sure fluid level is topped off and proper fluid is in it
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
BeatnikFink
10-01-2015 08:00 PM
