quick question..
no, set it to 42psi (stock). if you have a maf that's calibrated correctly it wont matter your running larger then stock injectors. the injectors need high fuel pressure to properly atomize the fuel
ive got afr heads ,holy systemax intake,75mm tb and 75mm maf, msd ignition. the car has nos but i havnt used it and dont want to until i get the damn thing running right. it seems to flood real easy too. ive had to change the plugs 3 different times now. but thats a different issue i posted earlier. thanks for the info guys.
autoedit
09-27-2015 06:37 PM
09-25-2015 06:30 PM
