Idle Problem Need Help!!!!
Old Jun 8, 2005 | 01:13 AM
birdman076's Avatar
birdman076
Default RE: Idle Problem Need Help!!!!
He's probably using a tweecer or tuner to adjust the dash pot, surging idle is usually caused by a rich condition. The idle adjuster plate which was mentioned works well, but a side effect on some applications has been a hanging idle when revved, a small price to pay for a steady idle and no stalling IMO. I had one on my car and it did cause the idle to hang a bit, but then I changed a whole bunch of sensors all at once and most of my problems are gone. I did have the surging, but now I'm down to just running slightly rich which I can sort of live with lol. I may try the idle plate again just to get the idle up a little, 700 with underdrive pulleys doesn't allow much charging at idle, and it seems to load up the motor running at that low as well with the X303 cam.
Old Jun 8, 2005 | 08:34 AM
stanglx2002's Avatar
stanglx2002
ORIGINAL: birdman076
Yes he does have a Tweecer RT
Also why such a low idle
Old Jun 8, 2005 | 09:49 PM
birdman076's Avatar
birdman076
Thats the way the car came, and if I dick with the idle at all it surges and won't stay put. Yes I have followed the idle setting procedure to a T as well, its just a quirk I have learned to live with.
Old Jun 9, 2005 | 12:34 AM
stanglx2002
do this:
Clean the IAC, MAF, TB
then replace the PCV valve and the screen
that should fix the problem
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
