how to test injetors
Old 11-28-2008, 11:58 AM
1988TTOP
1988TTOP's Avatar
Default how to test injetors
isnt there away to test them
1988TTOP is offline
Old 11-28-2008, 12:14 PM
gearbanger
gearbanger's Avatar
i would like to know to! where the gurus at lol
gearbanger is offline
Old 11-28-2008, 12:22 PM
primetime5.0
primetime5.0's Avatar
I had a local machine shop test mine
primetime5.0 is offline
Old 11-28-2008, 02:23 PM
crusin92red5.0
crusin92red5.0's Avatar
you test them with a noid light i believe. i read about it somewhere
crusin92red5.0 is offline
Old 11-28-2008, 02:35 PM
kaggriff
kaggriff's Avatar
noid light on test the connector at the injector. you can put twelve volts to them and see if they click. still will not tell you if they are gummed up inside. just that they are cycling
kaggriff is offline
Old 11-28-2008, 05:41 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
that'll only tell you if the injector driver circuit is functional, it won't tell you a thing about the injector itself, if you wanted to watch the spray pattern which is most valuable, I HAVE AN injector tester at work that'll vary voltage in the form of a duty cycle to turn the injector on and off and I have a test bench that I hook the injector to so it pressurizes with a cleaning agent
mjr46 is offline
Old 11-28-2008, 06:06 PM
Chuckles_5.0
Chuckles_5.0's Avatar
lol...well aren't you special.
so basicly just go to a shop? and run injector cleaner every so often...
Chuckles_5.0 is offline
Old 11-28-2008, 06:31 PM
mjr46
mjr46's Avatar
not every shop will have such, if you buy the correct test equipment , it'll pay for itself over and over
mjr46 is offline
Old 11-28-2008, 08:35 PM
88workcar
88workcar's Avatar
I made one at home, real crude but it works for me. You can only visualy see the spray from one to the other. I took an injector rail (one side) made a flat piece of alum with 4 holes in it. install the injectors in the rail, the alum bar on the bottom of the injectors. Put a big ty-rap on each end to sandwich them together. Takes some creativity because of the angle.
(I SAID CRUDE)
Then seal off one end of the rail tube. Put five foot or so of reg fuel line on the other end. pour carb cleaner in the hose, attach my compressor to the hose, raise pressure to about 60psi, use a spare injector clip set up with a momentary on switch and two aligator clips. Clip it on a 12 volt battery and bump the switch. I just move the clip from one injector to the next.
Please do not beat me up for the response, I got where I am today on the poor street where if you wanted it you had to do it yourself. And now I daily drive a 10 sec ride.
88workcar is offline
Old 11-28-2008, 09:47 PM
luckythirteen13
luckythirteen13's Avatar
(I SAID CRUDE)
thats actually not a bad idea. id probably take it one step further and add a small tank, fuel pump and reg. its a good way to test the spray
luckythirteen13 is offline
jwog666
12-27-2021 08:09 PM
Dathan
10-05-2015 05:52 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Florida Regional Chapter
09-30-2015 08:04 PM
GT350 S550 Tech
09-29-2015 03:29 PM
Quick Reply: how to test injetors
