Fuel pump problem
Old 12-22-2008, 08:25 PM
kurazee
kurazee's Avatar
Default Fuel pump problem
I finished putting the new engine in the car and I was excited to start it...but no, no fuel! The pump is not priming when I switch the ignition on. I've done a lot of research, searched the forums and done some troubleshooting without success. The car is a 93 and while the engine was out I replaced the heater core, what a pita! The red wire into the fuel pump relay under MAF has 12.2 volts to it and none of the others do when the igniton is on. The inertia switch is depressed but the green wire only has 6.6 volts. I'm clueless and aggravated. Any ideas?
kurazee is offline
Old 12-22-2008, 09:21 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
http://www.my5oh.com/forum/viewtopic.php?t=524 scroll down until you get to the no fuel tests and ecm not turning on tests
mjr46 is offline
Old 12-25-2008, 10:46 AM
kurazee
kurazee's Avatar
Thanks for the link. I haven't had a lot of time over the holidays but hopefully over the weekend I can figure this out. The post says I should have 5vdc on the orange/red wire of the TPS, I have 12.1v. I believe the ecm is turning on and I have a problem with the fuel pump wiring/relay. I am troubleshooting this by myself so it is hard to tell if the fuel pump relay is clicking. A friend of mine said I should have power in to the relay, I was figuring the 12v from the red wire, and power out from one of the other 3 inside the relay. Thanks.
kurazee is offline
Old 12-27-2008, 09:28 PM
kurazee
kurazee's Avatar
Any thoughts? I am hoping to put some time in tomorrow to fix this.
kurazee is offline
Old 12-27-2008, 10:04 PM
mjr46
mjr46's Avatar
the ecm controls the ground side of the relay windings and is done when the PIP signal is sent as an input from the stator to the ecm so that the ecm knows the engine is cranking and therefore sends an output command out grounding the windings triggering relay operation.......simply put once you start cranking identify the wire out of the relay that goes to the FP and if it becomes hot while cranking than you have a working FP circuitry and that is assuming the ground for the FP is good, if you don't hear the pump coming on and no FP is registered on a gauge that you should tap into on the fuel rail via a FP tester then you might assume you have a bad pump....that's to say your car is not starting due to lack of fuel
mjr46 is offline
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
cbird1177711
09-02-2015 08:51 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: Fuel pump problem
