HEADLIGHT PROBLEM
this does not happen always just every now and then ... when driving my headlights will blink on and off and some times go out completely . has anyone had this problem and what do you suggest ?. ive replaced the on dash headlight switch but didnt change anything . like i said it doesnt happen everyday just once in awhile
I have an 89 GT and when I put my driving lights on, my headlights do the same after approx a minute or a little less. Not to sure whats causing it. I replaced the switch too. Im starting to think it has something to do a an abnormal draw on power but my meter on the dash looks ok. Cant figure it out either.
check the grounds to the headlight,relay and the relay itself.
Start pounding on your steering column, dash and wiggle the harnesses, you'll get an answer
ccdguy
Sep 19, 2015 05:20 PM
