cheap c6?
cheap c6?
i know a c6 is heavy as hell, but i found one for $50 that apparently has a blown 3rd gear. would it b worth rebuilding and putting it in a fox at that price or should i hold out and get a c4
and the c-6 is gonna need rebuilding and 3 rd gear repair so your investment when all said and done won't be 50 bucks and to put it ina fox, you'll need the proper bellhousing , flexplate and tranny mount for either swap and if your not auto already you'll need a trans cooler and proper shifter for such a swap
well my fox is non exsistent at the moment but i might have found a cheap 5spd and i know the total investment wont b $50 but i doubt i will find a core for that either trans will get built
c4's are cheap, the one in my car now was $100, All I did to it wash flush it out with clean fluid and put in a filter bc it sat outside for a couple of years. It runs great.
c6's are heavy parasites that don't belong in a fox unless you are running a big block.
In your situation to where you have to build the transmission I'd stick to a C4. You wil come out cheaper in the long run. If you plan on making any trips you may want to consider a AOD
