z cam specs
Old 01-09-2009, 02:48 PM
mustangmike33
mustangmike33's Avatar
ok i got you on that, what would you all say to solid lifters? i was told to use solids too, but im kinda werry about that because i dont wanna wear down the lobes of the cam. and my heads are in the process of getting a stage 3 port job so i guess that cam would work well with them afterwards.
mustangmike33 is offline
Old 01-09-2009, 03:27 PM
Portmaster
Portmaster's Avatar
I'd stay away from a solid roller on your car. Because they require frequent adjustments it would really be a pain with that intake. Plus solid rollers are better suited to race cars and very limited street cars because they don't oil well at low rpm. Comp makes a EDM roller lifter that really helps but still the excessive spring pressures are a bit much for a street car.
Portmaster is offline
Old 01-09-2009, 03:30 PM
mustangmike33
do you know the specs on the cam you reccomended? hold on let me refraise that, can you give me the specs on that cam? im sure you know the specs, thats why you reccomended it, lol.
Old 01-09-2009, 03:42 PM
Portmaster
Portmaster's Avatar
Comp Cams XE274HR
Lift I/E 555/565
Druation @.50 I/E 224/232
Lobe Centerline 112
Intake centerline 108
Duration Seat to Seat 274/282
Old 01-09-2009, 03:46 PM
mustangmike33
thanks alot, ill check into this one!!
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: z cam specs
