broken tap
Old Jan 25, 2009 | 09:27 AM
herbie_hancock420's Avatar
herbie_hancock420
Default broken tap
alright heres the scop. i had a broken motor mount and when i went to change one of the bolts broke off at the head, not a big prob. so i drilled out and went to tap new threads, well to my luck the tap broke off clean and i have no clue how to get it out, any suggestions?
Old Jan 25, 2009 | 09:39 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
They make tap extractors. Otherwise, you're gonna have to get a punch and try and break it apart inside the hole. Done that before, it's not a fun job.
Old Jan 25, 2009 | 12:24 PM
herbie_hancock420
where could i find the tap extractor? auto value and auto zone both told me there was no such thing?
Old Jan 25, 2009 | 01:22 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
That's b/c they are morons and don't know anything. It is a speciallty tool.
http://www.google.com/products?q=aut...num=1&ct=title
https://www.redhillsupply.com/WLT18001.htm
Old Jan 25, 2009 | 01:32 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
best bet is to try and use a punch to get it out then install a helicoil
Old Jan 25, 2009 | 01:49 PM
MADMAC's Avatar
MADMAC
You can find them at a Grainger or Fastenal store, or a local machine tooling supplier. If ya know anyone that is a machinist, they could loan ya one. In alot of instances you will have to break it into small pieces. Always use lubricant when tapping. Dry tapping will get you in trouble most of te time. USE SAFETY GLASSES!!!!
Old Jan 25, 2009 | 02:47 PM
Tims 88GT's Avatar
Tims 88GT
Also when tapping go slow. Turn your tap in 1/2 turn then turn it back out 1/2 turn. Then turn in until it grabs again and go 1/2 turn in and then back out 1/2 turn. Do that till it bottoms out. Then remove the tap and spray the whole down with brake kleen or something to clean it out. Always use oil or a thread cutting lube with tapping.
Old Jan 25, 2009 | 05:18 PM
herbie_hancock420
Post
so i took a punch and broke the tap out and luckly i still had about 10 good threads in it so i got a new tap and sprayed out the hole first then retaped w/ lube and its good to go now. thanks for all the help yall are serious life savers.(and money savers!!!)
jwog666
Dec 27, 2021 08:09 PM
2007CalSpec
Dec 13, 2020 11:42 AM
Sep 25, 2015 06:58 PM
accarter
Sep 21, 2015 11:56 PM
stark777
Sep 21, 2015 12:46 PM
