Quick H/C/I Question
Old Feb 7, 2009 | 10:07 AM
Ketis's Avatar
Ketis
Default Quick H/C/I Question
I am doing a gt40 HCI on my 93 mustang with 91k miles.
When you replace the timing chain, is it standard procedure to replace the gears aswell? or is it ok just to replace the chain itself.
Old Feb 7, 2009 | 10:38 AM
kweb288's Avatar
kweb288
you dont have to replace the gears.... but while your in there whynot? one less thing to worry about,
Its mainly the chain you have to worry about since it can stretch and grow
Old Feb 7, 2009 | 10:45 AM
WhiteWindsor's Avatar
WhiteWindsor
What he said...if the gears are not worn it'll be fine.
Old Feb 7, 2009 | 12:18 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
freak a timing chain set is at most 30 beans, why go through all that trouble and not replace it as a unit??
Old Feb 7, 2009 | 02:49 PM
Ketis's Avatar
Ketis
Ok so i decided on getting the whole set
i mainly want to make sure everything is compatible with my gt-40Ps that im going to be putting in, mainly the valvespring set
http://store.summitracing.com/partde...rt=TFS-2500100
http://store.summitracing.com/partde...t=TFS-51402000
http://store.summitracing.com/partde...t=TFS-51478520
Old Feb 7, 2009 | 05:09 PM
OnyxCobra's Avatar
OnyxCobra
When i did my h/c/i i tried that timing chain and it didnt work for me. After i bolted it down it still had a lot of front to rear play so make sure you check that. The stock one didn't move at all so i figured it was wrong, i exchanged it for an FRPP one.
Old Feb 7, 2009 | 05:13 PM
1BIGMOFO's Avatar
1BIGMOFO
definitley replace the whole set. Its easy
Old Feb 7, 2009 | 05:32 PM
Ketis's Avatar
Ketis
does anyone else have any experience with this set?
id gladly pick something else if it wont work out ok.
im just kinda worried, this being my first time and all.
Old Feb 8, 2009 | 09:40 AM
Ketis's Avatar
Ketis
quick bump before i get the parts?
tmdm
May 2, 2021 02:49 PM
svfetter
Oct 5, 2015 11:39 AM
treesloth
Sep 28, 2015 07:03 AM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
