Opinions On Gear Setup
Would 4.10's or 3.73's or 3.55's be better with this setup and why?
(1990 Mustang LX 5.0)(5 Speed) Cobra upper intake with 1in. spacer,vortech s-trim supercharger 10-12psi boost,power pipe,sct programmer/chip,b-cam,ford racing roller rocker arms,75mm throttle body,90mm mass air,42lb fuel injectors,255lb fuel pump,high flow fuel rails,shorty headers,2 row aluminum radiator with aluminum fan blade,x-pipe exhaust,Mickey Thompson Street Slicks...
With 10-12 pounds of boost I'd go 3:55s. Blower motors make great power down low. At the strip what you would lose in the first 60' you would pick back up just past the 660' mark. I think the ET would be close to the same with all the gears but your trap speed would be much better with the 3:55s. Boosted motors don't need tall gears and high rpm.
...had to shift my car at 6800 rpm's to run those times & crossed the finish line at about 5900 rpm's...with 3.73's or 90's I could have shifted at 6200-6400 rpm's and ran the same times...my point I should have got at...
I had a Kenne Bell on my 02 for a short time with 4:10s. I put 3:55s in it and loved it. It seemed like it rendered 1st gear useless with the 4:10s. For a street/strip car I'd give up a tenth for the street power. I guess it really depend on the ulitmate goals for the car would be.
jwog666
12-27-2021 08:09 PM
