Torque Box Broke...
Torque Box Broke...
Hey everyone so I have been a long-time lurker and have gotten some awesome help and info just by reading and now I need some... Upon inspection for a 'shimmy' in the rear turns out my torque box is busted... Now I am trying to find a kit to hook it back together. I have found some and just trying to see what you think I would need. Here is a quick link to the ones I know about:
http://store.summitracing.com/egnsea...115+4294925008
Also here are a few pics of the problem...
If I could get one of those reinforcement kits to work that would be great. If not and you know about something else ALL help would be greatly appreciated. Thanks!!
If your on a budget just weld it all back together and make sure to weld on every seem like MJR said. If you have the extra money to throw at it and you plan to keep the car for a long time buy a set..
buy new boxes and have them welded in(labor is not bad),
after its cool, cover the repair with enriched zinc primer 4 coats and then 3 undercoating coats.
be sure to remove your carpet before taking it to the frame shop.
S-Box by Wild Rides----ADJUSTABLE UPPER CHASSIS MOUNT / REPAIR KIT FOR SEVERELY DAMAGED UPPER CONTROL ARM MOUNTING POINTS. This kit completely replaces both upper mounts and the uni-body cross member they are attached to. Multiple holes in our replacement box allows for multiple instant center changes for the ultimate in rear suspension tuning abilities. Weather you have already suffered a catastrophic failure or just want to upgrade to the first and only Bullet Proof Adjustable rear upper control arm mount, this kit is for you. Installs in 4 hours using; Basic hand tools, drill, sawzall and an air hammer will help. Once installed minor welding is required. Available for 79-93 & 94-04 Mustangs.
these , I have seen at the track on 600rwhp + cars, but im sure there are others
i would use an electric or air scaler to remove the paint, rust and debris to get a nice clean weld if your doing the work, but again, the cost for install is not that bad
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
