intake problems...
Old Nov 7, 2003 | 11:18 PM
importkiller10's Avatar
importkiller10
Default intake problems...
<FONT face="Arial, Helvetica, sans-serif" color=red size=3>i just installed a trick flow intake and have some trouble with it now. I do have a vacuum leak that was from the lower intake. I was told not to use the gaskets that go to the lower intake (the little S ones) and to just use a beed of silicone. when I took off the upper i noticed that there was oil on the back part of the intake. I think that was because I didn't use the gaskets. I also think that was my problem (vacuum leak). </FONT>
Old Nov 8, 2003 | 12:23 AM
vfast's Avatar
vfast
I ♥ Acer
what kind of silicone?
Old Nov 8, 2003 | 04:45 AM
importkiller10
<FONT size=3>RTV BLACK. I think that it's the b2r or something like that. Why? Did I use the wrong one? Let me know.</FONT></P>
Old Nov 8, 2003 | 05:03 AM
Banjo picker's Avatar
Banjo picker
(USE THE ULTRA GRAY SILICONE) AND WHEN YOU PUT IT ON MAKE SHURE YOU CLEAN OFF ALL THE OIL OFF BEFOR PUTTING ON THE SILI.OR IT WONT STAY. ALSO PUT A BALL OF SILI ON THE FOUR CORNERS WHEAR THE HEAD GASKET MEETS. ( NOT TO MUCH IT WILL END UP DOWN IN YOUR MOTOR) HOPE THE INFO HELPS
Old Nov 8, 2003 | 10:58 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Main thing with using RTV is to make sure the surfaces are clean and dry, and to let it bead (let it sit and get a semi hardened skin on the outside) before you put the parts together.</P>
Old Nov 8, 2003 | 03:04 PM
importkiller10
I did that when we put it on but I think that we didn't put enough it on. I think that another reason was because my bubby wanted the car out of his drive way and was doing it in a hurry. One other question. Would you use any type of gasket material (the small S ones that go between the heads)? I went to a mustang shop here in town and they told me that they don't use the gaskets they just use silicon.</P>
Old Nov 9, 2003 | 03:12 AM
83GT's Avatar
83GT
It doesn't matter which one you use. You can use the gaskets and silicone if you like doing it by the book (like myself), but you also have to use silicone, or you can do it with the silicone you just have to make sure it is clean and make sure you use enough of the right kind.</P>
</P>
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
