"clunk" when turning sharp
Old Mar 31, 2009 | 12:39 AM
LOUDexhaust's Avatar
LOUDexhaust
Default "clunk" when turning sharp
Car: 91 GT
When I turn really sharp in my car it makes a "clunk" sound. Ball joints are pretty new and the car is lowered a bit. I'm guessing something is worn out, maybe end links, rod ends?
Old Mar 31, 2009 | 08:20 AM
Portmaster's Avatar
Portmaster
Could be any number if things. If you can't check it out take it to someone who can before you are going down the road and your front wheels decide they want to go opposite directions
Old Mar 31, 2009 | 01:36 PM
Jfsram's Avatar
Jfsram
Some noises can be ignored depending on what it is but I'd never trust a noise in the front of a Mustang. The lower ball joints are being pulled out of their socket by design. Enough wear and like Portmaster said front wheels in opposite directions.
Old Apr 1, 2009 | 11:53 AM
Gary H's Avatar
Gary H
Check the sway bar mounts too. Mine did that and it was the bracket breaking off the frame...
Old Apr 1, 2009 | 01:24 PM
MonsterSN-95's Avatar
MonsterSN-95
Yea alot of times the sway bar links rust and snap then when the cars weight shifts you hear a thud.
Old Apr 1, 2009 | 07:54 PM
Tony71502's Avatar
Tony71502
My buddy had the same problem, sounds like you have a broken sway bar end link. (the part that connects the sway bar to the control arm).
Old Apr 1, 2009 | 09:14 PM
OnyxCobra's Avatar
OnyxCobra
My Mustang does this too, not really sure what to think of it. The whole front end of the car is tight, only does it when the conditions are just right.
Old Apr 1, 2009 | 10:48 PM
Shvltme_94SN95's Avatar
Shvltme_94SN95
my car tends to clunk when changing directions quickly, i think it is my tie rod. and i know my sway bar bushings are toasty.
Old Apr 1, 2009 | 11:20 PM
im_stuck_in_iraq's Avatar
im_stuck_in_iraq
i have the same exact problem...i turn the wheel it clunks i turn it another way it clunks if the car shifts at all it clunks..idk wtf it is...think its tie rod??
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 30, 2015 12:39 PM
logan409
Sep 26, 2015 07:43 PM
