Rate My Project Engine For My 88 5.0
well guys the worse happened, the tranny started 2 slip tonite, im pissed it wus just rebuilt like 4 maybe 5 thousand miles ago, i dont have the money 4 this, so im assuming that this big plan wont happen this winter anymore
I would go with the 331 stroker instead....still concerned about that oiling issue...check out the issue 5.0/4.6 tech guide issue for 2005 and read the 331 ways to waste a LS1 article....you may change your mind...this is what I will be doing for my 89 GT buildup...331 is almost 40 hp better at 6000 rpm than a 347....again depends on your application if you are going to race the car or not...if you want lower torque than you can go with the 347 but in my opinion the 331 package is still better...good luck in your decision
Jeff
project 89 GT resurrection
Jeff
ORIGINAL: 1991_5.0_Convertible
What would be wrong with him getting his car dyno tuned?
cardsrus1
19
Sep 15, 2015 08:37 AM
Sep 1, 2015 08:16 PM
kawiguy827
Sep 1, 2015 07:09 PM
