5.0 temperature issues
Hello Everyone,
I have a 1989 Mustang GT that is currently having an issue with the temperature. I recently installed a 180 thermostat and the car is still running a little hot, so I took it in to have it checked. The shop I took it to said that a pressure test revealed that the thermostat gasket was leaking, so they went and replaced this gasket. I have the car back now, and unfortunately the temperature fluctuates a bit, but seems to settle right at stock 195!
I asked twice if they replaced the stat with a stock 195 unit, they said no, they reused the 180. So, I'm at a loss, I've run 160 and 180 thermostats in the past and none of them fluctuated in temperature like whats happening now. I was wondering if this may be the result of a faulty water(coolant) temperature sender or the result of a crappy new radiator or perhaps the thermostat is bad, because I dropped it on concrete before the install. I'm racking my brain at this point, and no clues are evident.
The car ran perfect a month ago before the radiator blew up. The temperature issues really bother me and any and all advice/help would be really appreciated.
Thanks!
kaerts
Thanks!
kaerts
I'm located in Timonium, MD. BTW, the car is pretty resilient due to the fact that I've owned since 93' and it's been beaten daily. Anyway, true-true, a 195 is not hot I agree, but I've never really seen the temp stay at this position w/ a 180 thermostat + yesterday it was fluctuating near the 210 mark.
I should have paid more attention to the high pitched screeching from my engine bay, and I noticed it several days ago but didn't pay it any mind. I think the bearing on the water pump is blown; I think this solves the problem- what do you guys think???
1989, 50, coolant, fluctuates, good, gt, mustang, normal, proper, run, running, temp, temperature, test, thermostat
