Gauge Install?
Old Jun 8, 2009 | 06:53 AM
Five0hFox's Avatar
Five0hFox
Default Gauge Install?
Does anyone know of some tech write ups showing how to do mech temp, oil press, and voltage installs on a 5.0? The proper way to do it of course..
Old Jun 8, 2009 | 10:56 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Mech temp, remove the temp sensor that runs your gauge (I don't remember if its the front or rear sensor) and bolt in the probe for the gauge.
Volts, ground to the body and a wire off any power or straight to the POS on the battery.
Remove the bell sensor from the adapter and install the fitting that are with the sensor by the instructions. I recommend the mech oil pressure being outside the car somewhere.
Old Jun 9, 2009 | 02:41 PM
Five0hFox's Avatar
Five0hFox
you recomend mounting the oil pressure outside the car to advoid oil leaking into the car if it leaks? Is the oil thing towars the front on the driver side?
Old Jun 9, 2009 | 02:43 PM
1988TTOP's Avatar
1988TTOP
it is right above the oil filter
Old Jun 9, 2009 | 03:29 PM
projectresto83
M.A.D. Motorsports
Yup, having a gauge leak oil inside your car isn't a pretty sight. Especially if your carpet isn't black already lol. The sending unit is right above the oil filter like mentioned^. Yours should have a big bell shaped housing that is attached to a tube that extends it out about 3-4 inches or so. Those do come apart.
Old Jun 9, 2009 | 03:30 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
if you plan to mount outside the car I'd make sure the gauges are water resistant, or use elec gauges and mount inside the car
mtgldr
Feb 3, 2024 09:00 PM
Galactic
Apr 29, 2019 02:56 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
