new alternator
Old Jun 29, 2005 | 10:49 AM
Scooterman's Avatar
Scooterman
Default new alternator
how would i no if my 5.0 needs a new alternator.. my friend and i have been working on my car for 10 hours straight.. changing parts and what not.. and it has a new battery in it.. but the battery isnt charging up or sumthin.. does that mean my alternator is shot.. sum1 please help!!!!
Old Jun 29, 2005 | 11:23 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: new alternator
Advance Auto & AutoZone both test charging systems for free, just drive your car up there. Alternatively you could check your battery voltage with the car running... should be around 14 - 14.5 volts.
Old Jun 29, 2005 | 11:50 AM
Scooterman's Avatar
Scooterman
my battery is new.. i no that for a fact... the problem is.. it stays at around 8 volts or lower when the car is idle.. i dont think the alternator is working b/c it doesnt charge up the battery very good.. but im positive the battery is new
Old Jun 29, 2005 | 11:59 AM
Quik's Avatar
Quik
could also be a bad ground, could be bad connections on the battery, could be a fraided wire or the alt
Old Jun 29, 2005 | 02:29 PM
Scooterman's Avatar
Scooterman
well i just bought a new alternator... my friend and i tested the battery by putting jumper cables on 2 cars including the mustang.. and we established that the battery isnt the problem.. which is when we came up that the alternator was the problem... does that make sense?
Old Jun 29, 2005 | 02:42 PM
Djs94stang's Avatar
Djs94stang
It sounds like the voltage regulator or alternator. The voltage reg is mounted on the back of the alternator and it costs about $50. A rebuilt alternator will come with new regulator as well.
Old Jun 29, 2005 | 02:53 PM
Scooterman's Avatar
Scooterman
well im installing the new alternator today.. after it gets installed.. what should be different?? if the alternator was the problem.. does that mean my battery will charge and have more power?
Old Jun 29, 2005 | 03:03 PM
Djs94stang's Avatar
Djs94stang
You guessed it. It should run at about 14.5 volts all the time. The battery will only take a charge if the running voltage is higher than the battery voltage rating.
Old Jul 2, 2005 | 01:08 PM
Scooterman's Avatar
Scooterman
its at 12 voltz all the time.. i think thats normal too?
4cylinderplus2
Oct 9, 2020 07:45 PM
Golfsito
Oct 6, 2015 11:02 AM
MasterLanMan
Sep 26, 2015 10:03 AM
Wombatnation
Sep 13, 2015 09:16 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
