missing oil pan bolt
broke a bolt on in the pan rail YAY
wont come out with easy out tool
should i tap a new hole or just leave it on and hope it doesnt leak
front looking at it its pretty sealed up i put some extra silicon were the bolt is missing
just want some second opinions
its not main or rear bolts one of the corner bolts
thanks
thanks
oh im sorry i mean its stuck in the block and i dont think that comes off if i remeber correctly. its lodged inside the block nothing sticking out =( that easy out wasnt too good i ws thinking of aldren drill out tools maybe i can pick up from somwere
so it will most likely leak ya?
well it was me id just leave it and fix it if it ever does leak.my car has a bolt broke off in it from a previous owner and its never leaked on me.just got some silicon built up around it.
ya thats exaclty what i did, like i took a flash light and did a little sweep to see if there was any holes and it was all flush but when the bolt brok off i put silicon on both sides of the gasket were the bolt is missing. then i took extra silicoon and put it in the area were the bolt is missing, and then when the rest of the pan was on and bolted down i put some along the sides to make sure they wasnt any leaks, but i was haveing second thoughts about it this morning. but in my opinon they way the silicon looks around it doesnt look like its gonna leak, but just wanted a third party opinion
Here's what I'd try to do.
CAREFULLY center punch the broken bolt. Then get a left handed drill bit (1/8-3/32 inch) and a drill in reverse and carefully start drilling.
The broken bolt will come right out.
maestro1024
09-21-2015 02:40 PM
stangin1996gt
09-21-2015 11:01 AM
trashxtrash
09-20-2015 10:49 PM
