let motor breathe better?
sorry i apoligize i am new to the website and i am still learning how to use it ... i have been haven over heating problems the car will over heat after driven for a while or like wen sitting in traffic. it wont start after car is warm but when its warm and i through a charger on it, it will start but turn over very slowly.. i have a smaller wire running to the starter then the actuall battery cables can that be it but th only thing is it all worked before...the battery is in the trunk..the battery is grounded to the crossmember.. any advice will help thanks
Ok, that has nothing with having the motor breathe better. When did the problem start? Sounds like a dead battery but if it started after you relocated the battery then you need to make sure you cables are big enough and you have sufficient grounds. Battery to frame right where the battery is and a ground from the motor to the body.
As for the over heating, what fan are you running? What radiator? Do you still have the stock alt on the car?
logan409
09-26-2015 07:43 PM
