Need help with heads and cam.
Old Sep 19, 2009 | 06:47 PM
marcus33's Avatar
marcus33
Default Need help with heads and cam.
Will this fit my car?
Windsor Senior Iron Heads 2.02 Intake 1.60 Exhaust Valves, Dual Bolt Header pattern
My Car:
1989 mustang lx 5.0
3.73 gears
bbk throttle body
functional ram air
9mm wires
also if i put these heads in what kind of intake upgrade would i need to compliment it and what cam to go with them both?
i was thinking Edelbrock
Performer RPM II and a e303.
Any ideas-suggestions-criticisms.
Old Sep 19, 2009 | 08:24 PM
AdderMk2's Avatar
AdderMk2
Banned
i still dont understand why everyone is always so hell bent on the friggin E cam
Old Sep 19, 2009 | 08:36 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
loose the e-cam, it was the first thing I sold on a block I bought recently
Old Sep 21, 2009 | 08:09 AM
marcus33's Avatar
marcus33
Default ok
So I loose the E cam, what would you recommend I get a f cam or maybe a custom built one for my car?
If you believe I should go custom, does anyone know of any places that do custom cams and the price?
And no one has answered my first question. Will those heads fit on my 302 fox?
Old Sep 21, 2009 | 08:54 AM
mjr46's Avatar
mjr46
I wouldn't go after an f-cam either, why?? being that you are using a stock bottom end with valve reliefs cut into the pistons meant to be used with stock heads, depending on cam choice you may end up with ptv issues due to the larger 2.02 valve, in that case you'd be left flycutting the pistons.....not a terrible job but can be intimidating for a first timer, so in your case if you wish not to mess with such , I'd recommend a custom cam that way the valve events could be taylored to not create any ptv issues with a 2.02 valve in use with your inline valved head choice.......www.flowtechinduction.com or www.camshaftinnovations.com can serve your needs in this case, yeah custom cam is more, just a little more but if you have to pay to have your pistons flycut or buy the tool your no further more into it financially.........also custom can max your combo's potential
Old Sep 21, 2009 | 03:07 PM
Skyler5.0's Avatar
Skyler5.0
forget the letter cams all together...
Old Sep 21, 2009 | 10:02 PM
tinman's Avatar
tinman
Yes BTW. The heads will fit the car.
I'm sort of like the rest, do better than any of Ford's letter cams. They are a 20+ year old design that is way out-classed by many other grinds. Comp cams makes some good ones that are off- the -shelf. As does Trick-Flow(Summit Racing0............
Old Sep 22, 2009 | 07:37 AM
marcus33's Avatar
marcus33
Default :)
Alright then i guess that answers all my questions thanks guys.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
mustangheaven
Oct 7, 2015 10:23 AM
Drastang
Sep 30, 2015 03:48 AM
