5 lug axle ?
5 lug axle ?
I'm planning on doing a 5 lug swap on my 90 GT using 94/95 front spindles 13" cobra rotors/calipers in the front and the cobra 11.65" rears. When picking the rear axles would it be better to use stock left side ranger axles to keep the stock width or use the sn95 axles? I would like to run at least 17/9's in the rear with 275/40/17 if they can fit or 17/10's.Any ideas?
Thanks Chuck
Thanks Chuck
Thanks Chuck
Thanks Chuck
also, keep in mind that you are going to increase the track width of your rear by 1.5" so you should stick to a 17x9 wheel, otherwise its going to stick out of the wheel well and look REALLY retarded
KingRando
10-02-2015 08:06 AM
09-24-2015 09:18 PM
09-10-2015 08:39 PM
