d00e heads
Old 10-20-2009, 02:27 AM
Tberg725
Tberg725's Avatar
Default d00e heads
What do I need to do to them to put roller rockers on them I herd the rocker arm studs got to be changed?
Tberg725 is offline
Old 10-20-2009, 06:35 PM
Tberg725
Tberg725's Avatar
bump.
Tberg725 is offline
Old 10-20-2009, 07:44 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if they have pressed in studs, the heads will need to have machine work done to them and have screw in studs installed after they are prepped for such
mjr46 is offline
Old 10-20-2009, 10:16 PM
Tberg725
Tberg725's Avatar
Yup they have pressed in studs in them now.
Tberg725 is offline
Old 10-20-2009, 10:33 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
from what ive heard, the D00E heads are pretty much the best stock iron heads to get for fords.
as for the studs, you need to take them to a machine shop that has experience going from press in to screw in style studs. i think a little bit needs to be taken off of the face where they go in, but i might be wrong.
sn95_331_GT_ yellow is offline
Old 10-20-2009, 10:36 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
nah the gt40 are better as they are already setup for unleaded gas and pretty much the same head, iirc the gt40s flow slightly better....
but for stock SBF heads the 351C 4v out flow them all
rmodel65 is offline
Old 10-20-2009, 10:44 PM
sn95_331_GT_ yellow
i think i saw a chapter about it in one of my SBF rebuild books. ill take a look tmrw after work. right now the wife is demanding watermelon and a chick flick...
Old 10-20-2009, 10:54 PM
sn95_331_GT_ yellow
well, if youre going to go for 351C 4V heads, you might as well look for some C9ZE-A or D0ZE-A heads (69-70 BOSS 302).
anyways, back in reality land:
the D0OE heads have a 64cc chamber whereas the GT40's have a smaller one (61-58cc depending on the application iirc). not that matters too much but something to think about. personally, unless you want to build a mean sleeper i wouldnt bother with iron, i just like aluminum so much better.
although i loved the looks on the F body guys faces when they'd get beat and then see iron heads on top of my sled
lolz...
Old 10-20-2009, 11:04 PM
mjr46
mjr46's Avatar
set up right , I'd take c90e or dooe heads over gt-40's any day for their smaller combustion chamber that allows for more compression
mjr46 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
mustangheaven
10-07-2015 10:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: d00e heads
