AOD & Starter Removal with Long Tubes
Old 11-10-2009, 09:43 AM
speemike
speemike's Avatar
Default AOD & Starter Removal with Long Tubes
I am doing my AOD to T5 swap and having some problems. The car is a 93 lx with long tubes. I am having a hard time getting to the top starter bolt with the long tubes. Do the headers need to come out to get the starter out? Do the headers need to come out to remove the AOD? Any suggestions?
Also, I am trying to maintain the transmission cooler lines, is it possible to get these out without damaging them?
Thanks
speemike is offline
Old 11-10-2009, 10:28 AM
streetstang88gt
streetstang88gt's Avatar
you have to take out the passenger side header but not completely..you can just let it hang unbolted from the head...i just had to replace my starter a couple weeks ago and there was no working around it..
streetstang88gt is offline
Old 11-10-2009, 11:29 AM
speemike
speemike's Avatar
Hey thanks! I guess thats not a big deal. Do you remember if you used a socket or a wrench?
speemike is offline
Old 11-10-2009, 01:29 PM
zebo87
zebo87's Avatar
id say socket. should be a 9/16. that and a 6" extension.
zebo87 is offline
Old 11-10-2009, 03:51 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
just jack the motor up and get the headers out of the way, you'll be glad you did = will make the install go smoother
mjr46 is offline
Old 11-11-2009, 09:27 PM
speemike
speemike's Avatar
I finally got the AOD out with about 2 hours and swearing at the passenger side header. I finally ended up unbolting the passenger side motor mount and lifting one side of the engine. I think you are right I should unbolt the other motor mount and pull the passenger side header out before I go to install the T5.
speemike is offline
Jb145700
08-21-2022 06:37 AM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Luke9222
10-22-2015 11:55 PM
fastbackford351
09-12-2015 09:42 AM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
Quick Reply: AOD & Starter Removal with Long Tubes
