5.0 rebuild
i am thinking about ordering this kit http://www.summitracing.com/parts/FEM-MHP173-000/ , im looking into how much its gona cost to get it bored out i mite do it not sure. but i think im gona need my block surfaced decked and i was wondering how much that would raise the compression to. also with those pistons would it be bad for a daily driver what are side affects. if i get that those pistons its gna be a na motor, if i keep stock pistons it wil be built for forced indtroduction. also where can i get a girdle kit?? im thinken if i dnt bore it keep stock pistons and if i bore it go for the kit and raise the compresion.
it does nothing, it's a complete waste of money , the 5.0 roller block is what it is weak for high hp and rpm applications, a valley girdle will not stop main cap walk or chatter, all any girdle will do is keep the two split halves from going all over the track....hopefully
The "ZOMGZ LEVEL 10000000 D.S.S GIRDLE BLOCK" is a crock of ****, a stock block is a stock block is a stock block.
decided keeping stock pistons, trying to find gt40 **** cheap asap if anyone has any leme know. cuz i dnt feel like freshen up the stock heads. i found a machine shop im proly gona get the parts from. if not im geten a kit from summit.
Matt's 95 Stang
10-05-2015 07:16 AM
treesloth
09-28-2015 07:03 AM
