throttle body question
RE: throttle body question
ORIGINAL: vfast
you can also put a T/B Spacer which is a lil bigger than the T/B on as well some put a 67mm spacer with a 65 T/B.. but remember you have to open up the opening in the intake
fixed
save the money, buy a 3 stone cylinder hone from the parts store and hone out the spacer and the opening of the upper intake. dont get radical, use a tape measure to get them as close to the size of the TB as possible, a little bigger wont hurt, smaller will. also, your stock maf will also be a restriction with the bigger TB, so when money allows get a bigger one. the c&l 78mm works good. and you can get them for a little over $100 bucks.
no stone..just use a dremal tool with a 80 grit flap wheel.this will help to keep the opening round.then use a a small 120 git cone to smooth everything out..make sure you use a rag or rags to fill the opening to prevent shavings going in the engine..use a shop vac to pull them out before removing the rags
Luke9222
10-22-2015 11:55 PM
