transmission problems
Old Dec 5, 2009 | 06:16 PM
mustangsneverdie's Avatar
mustangsneverdie
Originally Posted by Jfsram
Why guess if it's the transmission OR the flywheel.
Run the engine so it vibrates. Push down the clutch pedal. If the vibration is still there, it's NOT the transmission.
just because you push in the clutch doesn't mean the trans. stops spinning you still have the driveshaft moving,don't you?
Old Dec 8, 2009 | 07:51 PM
aode08's Avatar
aode08
If its vibrating to where you cant drive the car, its the flywheel imbalanced or MAYBE throwout bearing damaged
Old Dec 8, 2009 | 09:53 PM
Jfsram's Avatar
Jfsram
Let's assume you are not moving. Car is sitting still. Wheels, axles, driveshaft is not rotating. Engine running with the clutch pedal up.
So the crank, harmonic balancer, eng accesories, flywheel, pressure plate, clutch disc, transmission input shaft ALL spinning. If you have a vibration during this situation.
You can now press the clutch pedal. The pressure plate releases the clutch disc, it will stop spinning in a couple seconds and so will the input shaft of the transmission, so that is what I meant.
Now with that all said. I highly doubt something in the transmission can cause a vibration and still work properly. If the transmission shakes the car it's WAY OVERDUE for fixing.
Old Dec 11, 2009 | 10:59 PM
93TROUBLE's Avatar
93TROUBLE
if your flywheel, balancer, and crankshaft is at a 28 oz. balance. then it could be the ride height of your car. but if u havent lowered or lifted it then check your u joints or maybe your drive shaft ( oil or dirt build up, dented, or off balanced ). but if its not any of the above.... then sell and rebuild !!!!
04stangman
Sep 26, 2015 09:33 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
