need some code help
Old Jul 21, 2005 | 07:07 PM
Tims 88GT's Avatar
Tims 88GT
Default need some code help
hey everyone, i am pulling codes on my car because i did not pass emissions, my car is supposly running lean. the code i got is 4112941294 i think 4 is an id code which means nothing, the first one is a brake and the 129 is my code, which is (manifold absolute pressure sensor or mass air sensor-insufficient signal value during Dynamic response test/engine run self-test) what dose that mean? i replaced the map sensor wich was $80 wasted because i got the same code.[:@]
Old Jul 21, 2005 | 07:20 PM
Quik's Avatar
Quik
Default RE: need some code help
do you have a vaccum line cracked or off?
a few weeks ago i got codes in truck P0171 and P0174 they were listed as extremely lean by 25%
so i checked my vaccum lines good*
checked my MAF to see if it was dirty, good*
checked my air tube to my TB, it had came off so i reconnected it no more code
so i would check for vaccum leak, check to see if your FR is good, see if your MAF is dirty [dirt will get trapped on the sensor from an overd oiled K&N]
hope that helps some
Old Jul 21, 2005 | 07:32 PM
Tims 88GT's Avatar
Tims 88GT
i checked maf and cleaned, i guess ill do that again, use carb cleaner right? all vacume lines are good, its not sucking air in after the filter i checked that, im not shure what it could be. thanks for the help.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
mustangheaven
Sep 29, 2015 11:00 AM
