Speedo Cable TOASTED!!! (ADVICE???)
my speedometer and odometer havent been working since ive owned my 5.0...i got under the transmission and noticed that the cable had been hitting the exhaust?? the outer black plastic has melted exposing the inner wires or whatever its made of.....but its still in tact.
ive never replaced a speedo cable before, and i dont know if its still any good. any advice??
i replaced the cable...now its working but im guessing the car has gears. I marked the driveshaft and spun the passenger side rear wheel one complete turn...the driveshaft spun 4 times...im guessing it has 4.10's. so now the speedo works but i think its 10-15mph above the speed im actually going...
what year is the car and what trans ??
as long as it isn't an aod... you can get it close, if it's a '89 or older t5... you can get it right on with a driven gear swap... takes 5 minutes and $20
ok your good
'89 has a 7 tooth drive gear... so a 23t driven will work perfect
only prob is they are a jeep gear not ford... so it will sooner or later wear out, but will get you correct
everyone who sells a 23t is the same thing, check ebay, saleen etc.
oh ok...7 tooth huh?? earlier today when i removed the cable out of the transmission i saw the end which is some sort of sensor..(well it has a plug connector) im guessing thats the speed sensor...anyway, it was black, and it had more that 7 teeth if i recall correctly??? its an '89 stang, but is it supposed to have a 7 tooth gear or what???
breaking
10-02-2015 01:27 PM
