Starting my car.
Starting my car.
Every time i start my when the engine is cold, i have to turn the ignition twice for it to start. Shouldn't it start right up without having to crank the engine twice with the acceptation of starting in < 32 degrees weather?
it means fp is bleeding off internally as long as there are no external leaks, if it's an inj , it bleeds into the head runner/ cumbustion chamber, if it's a pump issue or reg issue it just bleeds back to the tank
well its no big deal to mean. as long as i can start the car i'm fine. but if the problem is something i should get fixed because it could potentially damage something then yes, i have reason to fix it.
That sounds about right. the fuel pump was replaced nine years ago and then it sat for 8 years in a garage, (thankfully!) before i bought it. maybe it was replaced wrong.
