5.0 died while driving!!!
Old Feb 5, 2010 | 04:48 PM
5.0 Vertigo's Avatar
5.0 Vertigo
Originally Posted by MustangBradley
You seem to have followed the path on finding out what is wrong with your car. Do you have a way to swap out the ICM and eliminate that as the cause? You said you have power to it but perhaps it is bad. Just a thought.
If I have power in the harness going to the TFI on the ICM/RUN pin, wouldnt that tell me I am all good there?
Old Feb 5, 2010 | 07:44 PM
MustangBradley's Avatar
MustangBradley
You could be feeding it power but if it is damaged, it won't respond. My comment about the ICM is a guess. I have no specific reason to suspect it as the source of your problem. You seem to have chased the TFI and the PIP so what is left? The ICM and at worst, the computer. I would still be interested to see if you have any fault codes just to rule everything else out. It is like when you check the fuse last in a circuit that has failed. Sometimes, it is the most obvious thing that we overlook.
Old Feb 5, 2010 | 09:03 PM
5.0 Vertigo
Where is the ICM? I know the computer is in the right front kick panel. How do I check the codes? do I buy a unit and plu into the comp?
Old Feb 6, 2010 | 08:15 AM
MustangBradley
My second mustang was a 89 lx5.0. After all of these years, I don't remember where the ICM is. You have an 88, so you can figure on problems showing up from time to time due to age. I suggest you buy a Haynes manual for your car. Make sure that it has a wiring diagram in the back. With that, you can find out exactly where the ICM is and the procedure for troubleshooting it.
As for the codes, the manual will explain how to do it. You can use a test light or a multi-meter. I am serious about the manual. It will be the best $20 you spend. They have them at the chain autoparts stores.
http://mustangefiswap.blogspot.com
Old Feb 8, 2010 | 12:00 AM
dreamer1uk's Avatar
dreamer1uk
Originally Posted by mjr46
I gaurantee you have not tried everything or you'd have solved the prob...try this
http://sbftech.com/index.php/topic,588.0.html
Everything Mjr46 posted will help you figure out a no start EFI issues.
Also look at this - http://351winsor.com/joel/Ignition_Systems/tfi2.html
Everything is explained in detail on how to test the TFI and PIP as well as the control circuits. Its very simple stuff It sounds like you have a TFI issue or wiring issue going to and from the TFI thus you not getting a PIP signal. Again PIPs can be tested easily with a test light.
And the ICM is the TFI module.......
Old Mar 6, 2010 | 05:09 PM
5.0 Vertigo
Thanks for all your help troubleshooting guys!! It ended up being the EEC Power relay.. Go figure!
Old Mar 6, 2010 | 05:55 PM
89LX5pointO's Avatar
89LX5pointO
Glad you found what it was! I was gonna suggest seeing if that fuel shut-off switch accidentally got tripped in the trunk or somethin...but nevermind haha
Nick Oliver
Oct 17, 2018 04:22 AM
carid
Jul 8, 2016 09:55 AM
zachary1988
Sep 4, 2015 03:04 PM
TimeLord101
Sep 4, 2015 09:27 AM
5.0 kevo
Sep 3, 2015 06:24 PM
