how to tell if you have a spun bearing
If you pull them all, one at a time, and hear no reduction in knock, then you need to start digging. Since your removing the spark, the cylinder won't fire, therefore having ALOT less load on that cylinder...that's why it will get quieter when it's a spun rod bearing.
Use this approach as a "direction" on where to start looking BEFORE you start pulling parts off. It can save you alot of uneccessary teardown and at least give you a start one where to look.
Good Luck!!
I would do what I recomended first > You said the noise was at the bottom rear of tyhe motor . With out checking further maybe the noise is actually in the bellhousing. Just trying to save you work . Main bearings rarely spin.
i wish i would have thought of pulling one spark plug at a time before i drained out the oil. i was thinking the noise could be in the bell housing but i did drain the oil a month ago and it was metallic gray so i have a bad feeling it's going to be a bearing
KingRando
10-02-2015 08:06 AM
Offendant
09-23-2015 07:21 PM
ccdguy
09-19-2015 05:20 PM
