Help with ticking only after car warms up.
Seafoam works good in oil.
Unless you you think it is piston slap, I would think it would be a lifter collapsing or a loose rocker.
Run the Seafoam then readjust the rockers. If you take the rockers off the number one piston and the pushrods are not level when they should be, you may need a set of lifters.
may want to try a heavier weight oil next time too.
It's just a lifter!!!!!! When it warms up as stated by Tony and A_peguin, it gets louder. Lifters are just a hydraulic cylinders. When they start to wear out they will get noisey, the warmer the engine and oil the less internal pressure they are going to hold. Even if you adjust it you are going to have the same problem. Some go sooner than others. Make sure oil is getting to it through the galleys to fill the lifter also.
If your pour COLD oil into a warm lifter, it will quiet it down for a little bit.
ShaneB26154
35
03-04-2021 04:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
