thinking trick flow or gt40p
You can use the stock springs with the stage 1 cam, but if you must you can normally find the springs suggested for use on the cam sheet!
http://www.summitracing.com/parts/TFS-51400413/
those should work fine if you are worried about your stock springs!
the stock springs barley work for the stock cam. Mine where holding crap pressure and caused valve float, which made a nasty nitrous backfire.
once again, ALWAYS upgrade your springs with ANY cam. The company that makes the springs should have guide lines on how to pick there springs.
Luke9222
10-22-2015 11:55 PM
09-10-2015 08:39 PM
