relay question...
Old Mar 29, 2010 | 07:27 PM
uvastang's Avatar
uvastang
Default relay question...
ive got a 93 mustang and just put a 5.0 in it ... i got a wiring harness for the 93 mustang off ebay since the engine was out of an 87 and was speed density... but on the wiring harness i think what i figured out is that theres 2 relays right next to the mass airflow sensor but i dont have the 2 relays.. both connections look the same and i think i figured out that one is the fuel pump relay and the other is the WOT a/c cut off relay but i was wondering if they were both the same relay? if i could just buy two of the same or where i could find the 2 relays???????
Old Mar 29, 2010 | 07:56 PM
Bubba 95SN's Avatar
Bubba 95SN
go salvage or Ford dealer. Wait a minute someone will know
Old Mar 29, 2010 | 08:03 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
parts store should have a relay
look and see if it has metal connection for 4 or 5 prong relays then buy the relay
this would be a 4 prong relay. A 5 prong will have an 87a
also, look under the driver's seat. On some cars, the relay for the fuel pump is under there
Old Mar 29, 2010 | 10:08 PM
uvastang's Avatar
uvastang
no there is nothing under the seat..87 to 90 was under the seat but 91 to 93 is in the harness i believe....... on my 4 cylinder it was in the computer harness... so when i got the 5.0 harness theres 2 relay connections but not relays in them.. i think i found that they are the fuel pump relay and wot a/c relay but im not positive on which is which or if they are the same relay i can get 2 of or something?
Old Mar 29, 2010 | 10:35 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
there is a note at the bottom of this pic that has the part number for the relay. They both use the same relay.
Old Mar 30, 2010 | 06:53 AM
uvastang's Avatar
uvastang
thanks a lot!!! exactly what i needed to know!!
piotrek53
Oct 13, 2015 06:54 PM
Seanam
Oct 4, 2015 10:15 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
jc409
Convertible Tech
Sep 24, 2015 03:38 PM
schecterplayer
Sep 23, 2015 08:38 AM
