leaky valve cover
leaky valve cover
does anyone know a trick to stop chrome valve covers from leaking? i have a small drip once every few mins when the engine is at idle. i have tried a simple rubber gasket, and red high temp silicone but to no avail. any ideas? thanks
Obviously it's not sealing somewhere, is the valve cover damaged any where it seals? make sure both surfaces are very CLEAN before putting a new gasket on..i'm currently using the FEL-PRO gaskets with compression stops...no leaks! make sure the gasket is lined up and torque the bolts down evenly so it seals all over.
If the cover is flat on the sealing surfaces and not warped, then try a cork gasket and glue it to the cover with Permatex's "the right stuff" and then glue it to the head with the sealer also have you verified the leak is indead coming from the newly sealed covers???
I used to have the felpro gaskets on my nova that were cork/steel/cork. I used permatex on the valve cover and white lube on the head side. Never leaked a drop and i was able to pull the covers off several times and just re-white lube them to the heads. (playing with new heads/valve adjustments) I have been out of the the building world for a while, so i don't even know if they still make these gaskets anymore.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
