Switching a/f guage
Switching a/f guage
So i am putting new O2 sensors in the mustang in the next month or so and was debating putting in a a/f guage while I was messing around down there. My car isn't really anything that would require the guage, but they aren't expensive and would be a good diagnostic tool IMHO.
My question is has anyone seen a way to wire it so you can switch between the O2 sensors to get the ratio of the left and right banks? At first a simple switch would seam to work, but I am worried about losing voltage betweeen the multiple connections and additional wire. Does anyone know if this would be an issue, or seen it done?
Thanks,
vt
Thanks,
vt
Regular o2 sensors don't provide enough detail to realistically provide info to a gauge.
You'd need to install a 3rd one, they have a specific name to them but i'm having the king of all brainfarts right now.
edit: thanks mike. WIDEBAND. yah. that.
a gauge hooked to the stock o2 sensor will tell you nothing. there is no diagnostic info you can get from them.
like others have said, you need a wideband o2 for diagnostic info. itll require you to drill a hole in the exhaust and weld in a bung for the new o2 sensor to thread into. itll also set you back a couple hundred bux.
A regular o2 sensor is only designed to tell the PCM whether the mixture is lean or rich. It won't give an accurate, and readable, A:F ratio.
Your $40 gauge will work, but you'll need a wideband sensor in the pipe to make it work.
another reason to go with the wide band is those crappy 40$ gauges you have to splice into the o2 harness and after time it cuts through the wire causing a mf***** of problems trust me not worth it been there
