Car won't start
Don't waste your time with the ignition. You need to get it cranking first.
If you cross the 2 big lugs on your starter solenoid and it cranks. This verifies the starter, battery, starter wires are good.
If the starter solenoid clicks but it will only crank when you cross the big lugs. Probably the starter solenoid.
If no clicking, then you need to check the 2 small lugs. One should be grounded when in neutral or clutch pedal down. The other should be hot when the key is at start position.
KEM Motorworks
08-14-2015 10:13 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
