Old Oct 23, 2015, 11:56 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
Key stuck in ignition
Old May 14, 2010 | 04:53 PM
ieatriceforbreakfast's Avatar
Default Key stuck in ignition
My problem is, the key is stuck in the ignition.
I put it in to unlock the steering wheel and now I cant get it out!
Any ideas?
Btw its an 88 LX
Thanks
Old May 14, 2010 | 05:18 PM
mattdel's Avatar
mattdel
going to need to replace the lock cylinder.
take the shroud off of the column, and turn the key to the Run position. Underneath the lock cylinder will be a tiny hole. Insert anything strong, like a pick, into that hole and press up while pulling the key outwards, and the whole cylinder will come out.
Old May 14, 2010 | 07:55 PM
Bubba 95SN's Avatar
Bubba 95SN
That's it? Yup, that simple...that's it. New set of keys to loose.
Old May 16, 2010 | 05:44 PM
ok, I got the cylinder out, and the key. Cant get it back in though... Do you mean I need to replace the cylinder? Is this just a junkyard part? what about keys?
Old May 16, 2010 | 06:34 PM
never mind... I figured it out haha
Old Sep 4, 2011 | 10:47 PM
stevestone1995's Avatar
stevestone1995
i have the same problem on my 02 gt, my steering wheel locks up and i cnt remove or take the key out is this because of some safetly feature it only happens sometimes and i can eventually get it out should i replace the cylinder? and also my power locks r starting to go is tht the acuators?
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
logan409
Sep 26, 2015 07:43 PM
