won’t start when col
Old 11-27-2003, 04:24 PM
morris
morris's Avatar
Default won’t start when col
1990 5.0 HO 20,000 miles on rebuild, starts easily, runs great except when the temperature drops below 30 degrees. Then it will start for 2 seconds or so and quit. Virtually impossible to start. New fuel pressure regulator, new ACT, new ECT, new TP Sensor, 36# fuel pressure. Any suggestions?
morris is offline
Old 11-27-2003, 05:39 PM
BoostedStallion
BoostedStallion's Avatar
buy a different car for when it gets that cold out.<IMG src=smileys/smiley4.gif border="0"></P>
BoostedStallion is offline
Old 11-28-2003, 04:31 AM
johnc
johnc's Avatar
Doesn't the fuel pump shut down when it has no oil pressure? I think you get an initial "shot" during cranking to start, then the pump needs an oil pressure signal to keep running. Cold temp and sluggish oil pressure build-up? Maybe a pressure sensor problem? Dunno how to check that-not sure if you want to ground the wire or not. Hair dryer and warm the oil pan to see if it goes away?<IMG src=smileys/smiley19.gif border="0">
johnc is offline
Old 12-01-2003, 12:00 AM
tyybo
tyybo's Avatar
welll before you take out your wallet try converting to synthetic oil and use ethanol gasoline, if you dont have access to ethanol, then just put 2 bottles of heet in every tank, i dunno it helped mine and it gest pretty damn cold in north dakota</P>
tyybo is offline
Old 12-01-2003, 12:27 AM
Pitviper100
Pitviper100's Avatar
or just buy another car for the winter
Pitviper100 is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
1TUFF302
11-05-2015 04:02 PM
StalkerGT
09-25-2015 02:41 PM
dalefrancis88
09-11-2015 07:15 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: won’t start when col
