95 GT no start issue...HELP!!
Old 07-27-2010, 08:49 PM
95yellowgt
95yellowgt's Avatar
Exclamation 95 GT no start issue...HELP!!
so i just bought my car sunday and everything was fine, now today i drive it to work everything it fine, go out to lunch (2 starts) and fine. get in it to go home and it won't start. what its doing is i turn to key to on, everything lights up, i turn to start and everything goes like its going to start but not a sound from the starter. its a 5 speed so me and a co worker push started it and i drove it home without and issue. its acting like the starter isn't getting any power what so ever, i didn't hear the solinoid click or anything, just dead silence. any suggestions on where to start?
95yellowgt is offline
Old 07-27-2010, 10:52 PM
SnakeConvert98
SnakeConvert98's Avatar
Starter solenoid is more than likely the culprit,, turn the key on,,make sure it's out of gear and ebrake on, use a screwdriver to jump across the solenoid if it starts then there is the problem,, if not ,, could be ignition switch itself OR neutral safty switch ,,,,,, you ARE pushing the clutch to the floor, RIGHT??????
SnakeConvert98 is offline
Old 07-28-2010, 07:22 AM
95yellowgt
95yellowgt's Avatar
yes clutch all the way to the floor....it acting as though i the clutch wasn't being touched and you were trying to start it. im gonna start with the relay since its cheap then go from there
Old 07-28-2010, 09:16 PM
95yellowgt
95yellowgt's Avatar
ok of course im missing the owners manual to tell me which relay is which under the hood in the distribution box so does anyone know which relay is whick in the box?
Old 07-29-2010, 12:04 AM
enix187
enix187's Avatar
wrong body style but isn't it on the fender well? the thing that the positive cable runs too, thats what it sounds like to me
enix187 is offline
Old 07-29-2010, 08:17 AM
95yellowgt
95yellowgt's Avatar
no solonoid on the fender only on the starter, its a 95, theres no click no nothing when i turn the key, but everything on the inside of the car acts like normal if i was starting it with the exception of a power draw, so i think that rules out ignition switch and i ruled out the relay this morning so its either the clutch safety switch or the starter/solonoid. anyone know the best way to get to that safety switch, im a big guy and tight spaces don't like me. i haven't quite figure out how im gonna get underneath it to since its lowered 1.5 inches
Old 07-29-2010, 12:13 PM
mattdel
mattdel's Avatar
clutch switch is on the pedal assembly, so if you can jam yourself in there, look on or near the clutch pedal lever for a little switch with 2 wires.
mattdel is offline
Old 07-29-2010, 12:59 PM
Bubba 95SN
Bubba 95SN's Avatar
Two bolts, two nuts, unplug wires, and remove seat. Now there is room.
Bubba 95SN is offline
Old 07-29-2010, 09:51 PM
95yellowgt
95yellowgt's Avatar
well i jambed my self up under the dash and in a thought of asking my self how am i gonna get my arm up there i look to my right and right being the hood release is a little pull out push in style switch, i pull it out push in the clutch turn the key and she fires right up, that you previous owner for telling my about the kill switch
Old 07-30-2010, 08:51 AM
Bubba 95SN
Bubba 95SN's Avatar
Put a kill switch in car for a buddy. He calls about 6 months later, car will not start. Run battery dead, recharged run just about dead again. He is really fustrated (car is toy not a dd so infrequent use) and asks if i can come help. Ask him about the kill switch to coil. I hear crickets in the background..hello hello? Nice talking to you, later.
zsmart
Convertible Tech
02-29-2016 08:33 AM
1TUFF302
11-05-2015 04:02 PM
StalkerGT
09-25-2015 02:41 PM
dalefrancis88
09-11-2015 07:15 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: 95 GT no start issue...HELP!!
