need help asap
Old Aug 10, 2005 | 07:58 PM
Tech8's Avatar
Tech8
Default need help asap
ok i have a b303 cam with 1.7 rockers. Will that work good with a turbo set up or should i ditch it and go with a f cam or is it not worth the hassle of changing it, thanks!
Old Aug 10, 2005 | 08:06 PM
wildstang87's Avatar
wildstang87
Default RE: need help asap
the Fcam will most kill the low end power, but give you more top end pull. on the other hand the Bcam makes good low end torque to move you while the turbo is spooling up, so i wouldnt make the swap. you would probably see more gain from a split pattern like the TF stage 2 though.
Old Aug 10, 2005 | 08:29 PM
Tech8's Avatar
Tech8
anyone else
Old Aug 10, 2005 | 08:42 PM
Quik's Avatar
Quik
honestly for a turbo setup ditch both of those cam ideas and got STOCK!!! or the ecam. turbos v8s dont rev that high. my buddy with his E cam setup is putting down 540 at teh wheels and shifts before 5k
Old Aug 10, 2005 | 08:56 PM
Tech8's Avatar
Tech8
more the input the better, thanks!
Nick Oliver
Oct 17, 2018 04:22 AM
DJ Piner
Sep 30, 2015 03:03 PM
fireboss343
Aug 21, 2015 06:25 AM
kirk35
Aug 17, 2015 08:42 PM
MelloYello
Apr 23, 2004 03:59 AM
