Idle fluctuates only when engine warm?
Old Nov 3, 2010 | 06:15 PM
Bladerunner's Avatar
Bladerunner
Fastlane Motorsports does excellent work and they should be
able to give you a tune that should cure your problems with your idle.
Get a tune/chip/dyno from Fastlane Motorsports and go from there.
Old Nov 3, 2010 | 06:43 PM
enix187's Avatar
enix187
I'm located near fastlane, but your tps should be set with your idle screw in the position that you want it in, set idle were you want it, then adjust the tps accordingly, my car did the same thing until i put the stock airbox back on (no clue why just fixed the problem)
Old Nov 4, 2010 | 11:44 AM
joes90gt's Avatar
joes90gt
Originally Posted by enix187
... your tps should be set with your idle screw in the position that you want it in, set idle were you want it, then adjust the tps accordingly
I adjusted TPS after car was ran to full operating temp. No difference. Still have to press accelerator to keep running once car has be warmed up a little. Engine acts as though it has a *slight* miss to it. Elec scan shows the eng is firing just fine. Smoke tested the intake with no problems found.
I tried cleaning the MAF again with CRC MAF cleaner, but no difference.
Turns out I have a 73mm C&L.
I never had any issues like this before the engine rebuild. No problems whatsoever.
Looks like I'll be making an appointment with Fastlane after all. This surging/stumbling/starting/idling problem is getting the best of me...
Old Nov 4, 2010 | 11:49 AM
enix187's Avatar
enix187
they do good work, and its the off season so an appointment shouldn't be too difficult
Old Nov 4, 2010 | 07:15 PM
lukep6470's Avatar
lukep6470
I had exactly the same problem with a '95 motor and it turned out to be an extreme lean idle on a warm start (18:1) until the ECU went into closed loop. Get your workshop to measure the af ratio on startup.
A quick fiddle with the open loop fuel ratio fixed it right up.
2007CalSpec
Dec 13, 2020 11:42 AM
Nick Oliver
Oct 17, 2018 04:22 AM
2007StangV6
Jan 28, 2016 06:09 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
5.0 kevo
Sep 3, 2015 06:24 PM
